It is currently Thu Aug 07, 2025 3:28 pm
 Post subject: Easy Foam Spreaders
PostPosted: Tue Mar 13, 2018 10:39 am
Like most of us, I made my own mold spreaders with wood and turnbuckles until I found a way to make them with 1&1/2" pink foam insulation board. I cut a dedicated spreader for each instrument model and insert them by opening the outside mold, positioning the spreader and then closing the mold for a slightly compressed fit. The foam is very friendly to the thin side material and form-fits itself through compression. The foam spreaders work for everything that I build, from ukuleles to jumbo body guitars. Each spreader is cut to be a perfect match to the instrument as opposed to the "one size fits all" approach of the wood & turnbuckle spreader.
If I want to leave the spreader in place while gluing on the top and back, I first cut it in half and allow the 2 halves to stay together through compression. After the top & back are glued in place, it is very simple to remove the spreader through the sound hole.
Mike Franks
www.mjfranksguitars.com
These users thanked the author Mike Franks for the post (total 6): jshelton (Wed Mar 14, 2018 9:47 am) • TimAllen (Wed Mar 14, 2018 12:15 am) • ernie (Tue Mar 13, 2018 6:15 pm) • Pmaj7 (Tue Mar 13, 2018 5:36 pm) • Colin North (Tue Mar 13, 2018 2:06 pm) • Bryan Bear (Tue Mar 13, 2018 12:31 pm)
 Post subject: Re: Easy Foam Spreaders
PostPosted: Tue Mar 13, 2018 11:02 am
Nifty...
PostPosted: Tue Mar 13, 2018 11:30 am
Great idea! Multiple layers of corrugated cardboard glued together might also work if the pink foam isn't handy.
PostPosted: Tue Mar 13, 2018 11:46 am
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
Yes sir! [:Y:]
PostPosted: Tue Mar 13, 2018 12:18 pm
ingenious...
PostPosted: Tue Mar 13, 2018 12:33 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Now that's a great tip! I'll have to remember this; I can see this coming in handy in other situations as well.
Bryan Bear PMoMC
PostPosted: Tue Mar 13, 2018 12:59 pm
First name: Brad
Last Name: Combs
Yep, I have a couple uses for this right off the bat. Good call.
PostPosted: Tue Mar 13, 2018 6:14 pm
Last Name: Beaver
City: Lake Forest
I sure do Like that idea!!!
Joe Beaver
Maker of Sawdust
PostPosted: Tue Mar 13, 2018 10:52 pm
City: Escondido
Zip/Postal Code: 92029
Yep. Adding that to my arsenal for sure.
PostPosted: Wed Mar 14, 2018 5:23 am
nice
Users browsing this forum: oval soundhole, ptourin and 10 guests
